Help Android 5.0.2 x Wireless web based authentication (captive porta ou web-portal)
  • Start date Start date
A
Android Question
Guest
Hi guys,
The wireless network that I use is a Captive Portal (or web-portal). I need to connect to the wireless, open the browser, try to access a site and then I will be directed to a login page where I should put my username and password. Only from this time the internet will work.
Since I have upgraded my MOTO G to Android 5.0.2 the issue I am facing is when I connect to the wireless and I am also connected with the data network (3G), the captive portal (or web-portal) does not appear and I can not authenticate to the wireless. If I turn off the data network and open a browser, the Captive Portal appears instantly.
Anyone knows how to fix that?
