Help Android 5.0: Lock Screen Weather Won't Work
  • Start date Start date
A
Android Question
Guest
I have a Samsung Galaxy S5. Ever since I upgraded to 5.0 Lollipop, the lock screen weather has gone away, even though I have it turned on in the settings.
I even tried putting my location services on high accuracy (I usually keep it on power saving) but that didn't do anything.
Anyone know why the lock screen weather will not work?
Go to Settings-Lockscreen and scroll down to additional information_click on it and check Weather
I had this problem with the transparent weather widget after the update - I uninstalled the app. and then reinstalled it upon being reinstalled it updated and the problem was solved. Hope this helps.
