Android 7.0 bluetooth connection issue
I presume this printer uses its own support app and/or driver that you install on the phone. Could be the app that's incompatible with later Android versions, like 7.x.
Check if there's any updates for it. If there isn't you might need to contact the printer's manufacturer, and enquire. That is the "developer" you should contact about this issue.
