HPH NT-N9 RK3328 Quad Core 4K TV box, the new line of TV box with Android 7.1 Nougat operating system.
So what can we expect from this new TV box, and is it going to be worth out time and money, or is it a good replacement for current Android 6.0/5.1 TV boxes? Well,let’s get into that below.
New Hardware
The NT-N9 uses the newest CPU processor. It runs on the Rockchip RK3328 quad core CPU, Cortex A53,running up to 1.5GHz.
1,Its 3D graphics and display, is powered by the ARM Mali-450 dual core GPU, running up to 600MHz.
2,Its RAM comes with 2GB DDR4(remark) ,and 16GB EMMC storage.
3,It has single band 2.4GHz WiFi,100M/1000M Ethernet and Bluetooth 4.0 supported.Importantly,also USB3.0 support.
4,It has 5.1 surround sound capability.
New Software
HPH NT-N9,runs on the new Android 7.1.1 Nougat operating system.
1,It can play movies and personal videos in 1080p,2K and 4K especially for real 4K@60pfs,quality with the included H.264,H.265,HEVC,and VP9 decoding,and also support HDR,10bit.
2, Watching unlimited streams of movies and TV shows from paid subscription services such as Lingcod TV,as well as via free TV or live streaming like Kodi 18.0,IPTV,Netflix,YouTube etc.
3,You can choose and install these apps your like from Google play store freely,as they aren’t preinstalled.
4,One more thing,this box,HPH NT-N9,its Media Center supports Subtitle Download for you!
Customer Usage
OK,so this box,HPH NT-N9,is a budget TV streaming box,it’s not so good at ultra gaming.If you don’t care about the little lower-end GPU for big games,and all you would like to do is stream movies with Kodi and other services,then this box is for you.
Benchmarks:
§ Root – Optional
§ DRM – Supported
§ Geekbench4 – 615 single and 1684 multi
§ Antutu – 36118
Conclusion
HPH NT-N9 RK3328 Android 7.1, 4K TV Box.It is pretty OK for a cost-effective box.You know,they implemented DRM .You don’t had to block root to protect against people getting into the system to change things.
So this box has DRM,root optional,and you can install or upgrade Kodi any time.For the tability,we played 4K video over 24 hours without Interrupting,you can trust it.
New Hardware
New Software
Customer Usage
Benchmarks:
§ Root – Optional
§ DRM – Supported
§ Antutu – 36118
Conclusion
