Android Application Problem
Check this class below,
______ My Code _______
public class Main extends Activity implements OnKeyListener {
DisplayWord currentWord;
TextView wordStatus;
EditText inputWord;
Button okBtn;
int pos = 1;
char currentChar;
char inputChar;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
currentWord = (DisplayWord) this.findViewById(R.id.trueWord);
currentWord.setText("Bonjure"); // word from database
wordStatus = (TextView) this.findViewById(R.id.wordStatus);
inputWord = (EditText) this.findViewById(R.id.wordInput);
inputWord.setOnKeyListener(this);
@Override
public boolean onKey(View v, int keyCode, KeyEvent event) {
if (inputWord.getText().toString().length() <= currentWord.getText().toString().length()) {
pos = inputWord.getText().toString().length();
currentChar = currentWord.getText().toString().charAt(pos);
inputChar = inputWord.getText().toString().charAt(pos);
} return false;
_____ END _____
When running this code, upon entering data into the input box it causes an exception straight away and for the program exit unexpectedley.
I am trying to extract the input word from EditText field and the word stored in a TextView and to compare them char by char as those chars are entered into the input box, sort of a word game, where the character will be highlighted green if it is correct and red if it is not.
I have no idea why this behaviour happens, I can see in debugger an StringIndexOutOfBounds exception, and a ResourceNotFound when I have been tampering with different ways of attempting this.
Any advice or links appreciated,
Anthony
