Android box TX 3 pro - help needed!!
lotcav123
Hi,
I have TX3 pro and I try to put a new firmware (old firmware didn`t want to install anything form google play, outdated, tanix support terrible) from here using Burn card maker:
https://chinagadgetsreviews.com/down...-tv-box-2.html
My steps:
- download that firmware
- burned firmware on sd card using burn card maker
- by instruction firmware should start automatically but it didn`t (it entered andorid normally) so I in the next attempt pressed reset button and I turn the box on with SD card in it. This time blue light started to blink and I waited 5mn but nothing happened. After taht I didn t hold reset button anymore.
- Now it blinks blue, when I remove sd card it just turn red light on, it won`t turn on.
- After I put card again and remove HDMI cable it has a solid blue light but it has no image on screen.
I thought that android box bricked.
I disconected HDMI cable, sd card was in device, blue light was solid and leave it liek that for 10mn. After I connnected HDMI cable I got some russian option dialog on box. I choose red option on that dialog because green wasn`t working and it seems that it put a new improved android on it. That seems strange to me , i am worrid that something should went wrong because I tried after unsuccessfully first attempt I tried to move sd card out, to turn power off, seems like there was simply no time for andorid to make a correct installation. To leave it like this or to try another attempt? I want to be sure that everything went OK...
Perusing through that link you posted, the download for the firmware is archived as a .rar file. After downloading it, when you opened that rar file up, was the indicated .img file (LC-ALE-1-TX3pro-20170228.img) there?
Yes I unpack that and burn that iso on sd card.
I tried again and this time android progress bar appeared and everything went fine!!! :D
Couple of questions:
- I use remote controler to navigate through android box, it is not best solution. I was wondering if I watch movie or youtube and then press menu button on remote controller will these app stay hidden/active in background or they are turned off?
- This custom firmware, are they safe?? I mean no hacking tool, backdoor, trojan or any other danger? Should I scan with some antivirus?
- I have program that scan autorun and when I put sd card from android box to my PC it told me this:
> K:\System Volume Information
> K:\System Volume Information\WPSettings.dat (MD5: cf77dd76f49134cd7c442b1ed533b5b1)
>>> K:\System Volume Information - Malware (folder) > Deleted. (18.09.21. 23.37 System Volume Information.430096)
=> Malicious files : 1/1 deleted.
=> Malicious folders : 1/1 deleted.
Dangerous?o_Oo_O
- every time I turn it on it tells me that it need update (option dialog box), any way to turn that off? Previous version didn`t had that, just boot menu than main screen.
Good to hear that the firmware flash process worked out after you tried again.
As for your queries, I don't have a TX3 Pro so just making assumptions in the hope that someone here in the Forum with actual hands-on experience will chime in with more definitive answers.
-- Generally when an app, especially one that manages a video streaming service, gets minimized into the background, the active video stream continues on as is.
-- This doesn't appear to be a custom ROM but rather that site was providing a copy of a stock ROM. Usually with a custom ROM that requires the device to be rooted, flashing a stock ROM however does not. As for its validity, that's hard to tell without actually directly comparing the two ROMs side-by-side. That site, China Gadgets Reviews, 'appears' to be legitimate but for anyone to determine whether any web site is or isn't legitimate anymore is a big, open question. I'd be leaning towards the firmware they provided is OK -- there's a bigger chance downloading a file from an individual hosting his/her own server is riskier than from a commercial venture. But again, there's no 100% assurance from one or the other, and determining just where GGR originally obtained that firmware is a mystery.
-- I would never rely on just one anti-virus/anti-malware utility if something is found during a scan. The chances of false-positives is actually really, really high and despite all the marketing B.S there is no utility in existence that can catch every exploit out in the wild. They typically have a success rate in the 40%-90% range, and that's always going to be based on a narrow time span (new exploits are popping up frequently and on a consistent basis so a utility may do great at detecting problems in one test but the next quarter, not so much).
-- As for that update message always popping up, try doing a Factory Reset (.. the caveat that backup anything you have saved as a Factory Reset will delete all user stored data). On a typical Android device, the internal storage is divided into several partitions -- most are dedicated to the operating system and one for general, data storage. I'm assuming (emphasis on that) your TX3 Pro is similar so the issue is with a Factory Reset, that only wipes that data partition clean. The big variable being different manufacturers set up their own products in different ways so for some, when flashing the ROM that wipes not just those system partitions but also that user data partition. But with some, like Samsung, flashing the ROM only affects the data partitions, leaving the user data partition as is. So when you re-flashed the firmware, that may or may not have also wiped the data partition. But if you initiate a Factory Reset on your own, at least that eliminates the possibility either way.
You might also want to try wiping the system cache partition. Again, not knowing just how your T3 Pro is configured, the flashing of the firmware may or may not have cleared the system cache partition, but it won't hurt anything to do it and can only help. But you do need to boot your device into it's Recovery Mode to do the 'wipe cache partition' option. Not familiar with a TX3 Pro so I have no suggestion on what the button sequence is to boot into Recovery Mode.
Thanks for detailed answers.
1) is there any program that with one click closes all applications? My andorid is not so fast, so I want to preserve ram memory and CPU usage.
2) This is my boot menu
This is the message:
My wifi is connected but it seems that it isn`t recognised on that screen. When I press exit it enters main menu and wifi is active. This seems to me like it is integrated in system. So you think that I should try factory resert and wipe cache partition? How to enter recovery mode, this time without SD card holding reset key?
3) How do I arrange programs on main screen?
4) I tried to disable that program that program that detects malware so I can find that file and upload it to virus total page but I can`t find it. I searched also in hidden file on sd card but there is no System Volume Information folder.
Not having any luck finding any definitive documentation on your TX3 Pro. Other than being well rated and getting good reviews it appears to a pretty good bargain ($30 range) for the feature set it includes. Did any kind of user manual come with it?
1. Are these the general hardware specs for your unit?
Android 6.0 OS
CPU:Amlogic S905X Quad Core Cortex A53 Processor up to 1.5GHz
GPU:Penta-Core ARM Mali-450
RAM:1GB DDR3
ROM:8GB eMMC
WIFI:IEEE802.11 b/g/n
LAN:10/100Mbps Ethernet
Support English, Russian, Hebrew, Portuguese, Spanish, etc., multi-language
VP9-10 Profile-2 up to 4Kx2K@ 60fps ,H.265 HEVC MP-10@ L5.1 up to 4Kx2K@ 60fps
3D, CEC, HDR and HDCP 2.2
HD MPEG1/2/4, H.265, 4K-HD, HD AVC/VC-1, RM/RMVB, Xvid/DivX3/4/5/6 , RealVideo8/9/10
Avi/ Rm/ Rmvb/ Ts/ Vob/ Mkv/ Mov/ ISO/ wmv/ asf/ flv/ dat/ mpg/ mpeg
4K@ 60Hz video decoding 10-bit HEVC and AVS+ codec support; H.264 up to 4K 30Hz
Hardward 3D graphics acceleration
MP3/ WMA/ AAC/ WAV/ OGG/ AC3/ DDP/ TrueHD/ DTS/ HD/ FLAC/ APE
HD JPEG/ BMP/ GIF/ PNG/ TIFF
Ports:
1*SPDIF
2*USB
1*HDMI
1*RJ45
1*TF card slot
1*AV
1*DC
With only 1GB of RAM that is a relatively low amount, but not bad for a single-purpose set-top box. The issue is Android's integral memory management is going to be more better than most of us are trying to do the same. Users micro-managing memory was a thing with Win98 and pre-OS X systems, not so much now. Most of the time we just end up creating a situation where the device is working that much harder to compensate for our actions. So killing background apps is good for our own peace of mind but it might not actually be optimizing RAM usage and making your device run better. Just be judicious about it.
2. Have you tried using an Ethernet cable to connect to your home LAN instead of WiFi? If that message is only popping up when using WiFi connectivity, try deleting the WiFi entry you added in the Settings menu and then add it back in again. You might also want to reboot your router, sometimes there's just some one-off networking glitch that will get cleared with a restart.
3. No comment, since there's not a user-interactive screen involved I don't know much granular control is available to you. Again, hopefully someone with actual experience with chime in.
4. If you're referring to some kind of anti-virus/anti-malware app that came pre-installed with your unit, the odds are you can't do much to actually uninstall it. That would require your device to be rooted. If there's any way to manage the installed apps in the Settings menu you might be able to disable it though.
It this one:
https://www.gearbest.com/tv-box-mini-pc/pp_397959.html?wid=1433363
I can`t find it anymore on Tanix web and Tanix didn`t respond to email or facebook messages. Shitty support.
2. I can`t connect it on LAN because router is on other floor and it far from TV. Restarting router didn`t help but I discover possible cause of that message. I entered some TV app on andorid and I got exact same message as on startup so I thikn that app is responsible for that (you have picture of app on my previous post, it is simply called TV). In setting of android there is no option to unistall app, there is an option to disable notifications but it didn`t help. App is integrated in OS so I have no idea how to remove it.
4. You misunderstood me, it is program on my PC that gives me warning.
http://www.mcshield.net/
On android box I have no antivirus software.
Update: I rooted my android box and then I was able to remove app that gave me that annoying welcome message. Also swithed home menu for something else. Firefox (and other browsers) was running really slow on my box, very stuttery with constant microfreezes. I disabled java script in firefox and now it runs much better. Is there any more tricks that I should now, something to speed my andorid box?
