scorpiobuzz
Alright, I decided to show some code in this one because I couldn't seem to convey the problem very well otherwise. Here is the calling class
And then this is the called class where I am trying to copy in the user's selection to the new database and then send back the id to the calling class.
I have been messing around with this thing for days and can't seem to get it to do what I want - any help would be appreciated.
Code:
static final private int CHOOSE_MONDAY = 0; static final private int CHOOSE_TUESDAY = 0; private int ButtonPushed = 0; private NotesDbAdapter mDbHelper; private MenuDbAdapter menuDbHelper; private Long mRowId; String menuTitle; String menuProtein; String menuBody;
@Override
// TODO Auto-generated method stub
setContentView(R.layout.plan_menu);
Toast.makeText(this, "Choose a day to pick a meal for!", Toast.LENGTH_LONG).show();
mDbHelper = new NotesDbAdapter(this);
mDbHelper.open();
menuDbHelper = new MenuDbAdapter(this);
menuDbHelper.open();
public void mButtonHandler(View target)
switch(target.getId())
case R.id.monday:
// Create new intent object and tell it to call the ColorPicker class
Intent question = new Intent(this, PlanMenuList.class);
// Start ColorPicker as a new activity and wait for the result
startActivityForResult(question, CHOOSE_MONDAY);
break;
case R.id.tuesday:
Intent question1 = new Intent(this, PlanMenuList.class);
startActivityForResult(question1, CHOOSE_TUESDAY);
break;
Code:
public class PlanMenuList extends ListActivity {
private List<Data>data;
String menuTitle;
String menuProtein;
String menuBody;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.notes_list);
mDbHelper.open();
fillData();
private void fillData() {
Cursor notesCursor = mDbHelper.fetchAllNotes();
startManagingCursor(notesCursor);
// Create an array to specify the fields we want to display in the list (only TITLE)
String[] from = new String[]{NotesDbAdapter.KEY_TITLE};
// and an array of the fields we want to bind those fields to (in this case just text1)
int[] to = new int[]{R.id.text1};
// Now create a simple cursor adapter and set it to display
SimpleCursorAdapter notes =
new SimpleCursorAdapter(this, R.layout.notes_row, notesCursor, from, to);
setListAdapter(notes);
private void populateFields() {
if (mRowId != null) {
Cursor note = mDbHelper.fetchNote(mRowId);
startManagingCursor(note);
menuTitle=(note.getString(
note.getColumnIndexOrThrow(NotesDbAdapter.KEY_TITLE)));
menuProtein=(note.getString(
note.getColumnIndexOrThrow(NotesDbAdapter.KEY_PROTEIN)));
menuBody=(note.getString(
note.getColumnIndexOrThrow(NotesDbAdapter.KEY_BODY)));
protected void onListItemClick(ListView l, View v, int position, long id) {
super.onListItemClick(l, v, position, id);
mDbHelper.fetchNote(id);
mRowId = id;
//populateFields();
menuDbHelper.createMenu("Monday", menuTitle, menuProtein, menuBody);
Intent answer = new Intent();
answer.putExtra("MenuDbAdapter.KEY_ROWID", mRowId);
setResult(RESULT_OK, answer);
finish();
