Gea T
Hello,
I am learning how to design interfaces for Android apps and just started my course on Udacity. I have a Windows 10 PC, Samsung Galaxy S7 edge, and iPad 4th Generation. I am struggling to put together a design pipeline and my questions may reflect my confusion, but please bear with me. I think what I am looking for is the most seamless experience from creating an interface, and exporting it to other apps or devices, using the best available choices of hardware and software. Thank you for your time.
Assumption 1: I do not have a big budget. The cheaper the better.
Question 1: What are the best combinations of an affordable drawing tablet for PC and UI design apps?
Question 2: Is it possible to put together a pipeline using my iPad, a digital pen, and apps on my PC?
Assumption 2: I do afford new hardware and software.
Question 3: What combination of hardware and software do you recommend for designing interface for Android? ( I do have installed Android Studio on my PC).
Best regards,
G.T.
Best regards,
G.T.
