Apps Android device screenshot captured problems
khoapn
Hi, folks
I found a problem need your ideas
I captured Android screen shots from device using Dalvik Debug Monitor. On the same screen, after I manipulate smth and come back, the screen captured at this moment is not completely identical.
Especially when viewing an image in Gallery and capture screen, next time view him again and capture. Use some graphical editor i saw that the brightness or contrast is different (by human eye we couldn't see that)
(see ex, the red color shows the different
1st time capture
2nd time capture
diff:
Another example:
1st time capture
2nd time capture
diff:
Anyone get this problem before???
Maybe your problems relate to one of these reasons:
- Power management mechanism: the background brightness or contrast was adjusted to adapt power status (?)
- Double-buffer management: Android display works by flipping these buffers. Due to some problem of buffer status, the display can be difference (?). I am not sure this part, hope it is a clue for you.
- Problems in applications them-self ?
