Apps Android Eclipse problem
I followed the exact steps for installing ADT plugin for Eclipse 3.4.1 Ganymede
However I cannot find (Android) item under: Eclipse>Window> Preferences
Please help! I have a university project which needs to be developed on android platform :(
Once you installed the ADT plugin, did you restart Eclipse?
If you did, try removing and reinstalling the plugin, I've had weird issues like the one you're describing that have been fixed with a reinstall of the plugin.
Its an install problem with Equinox P2 updater..
Down and install the Eclipse 34.1 RCP version..that version works
a little late now but for those who may still need help ... I installed eclipse as root, so it needs to be ran as root to complete the adt installation so that this will show up in preferences.
