I recently bought a BLU Studio Energy as a travel phone/secondary phone. It is running Android 4.4.2, but it's not entirely stock.
This is where the problem lies. I'm told that usually in Security you have the option to turn on Encryption after you set a pin.
Unfortunately this is what I get...
https://imgur.com/a/PyWKV
Do you know of another way to turn full disk encryption on?
Do you know if rooting the phone will solve this, and if so, any suggestions about going about it? (http://androidforums.com/threads/root-blu-energy-help.904974/ talks briefly about rooting)
Has anyone had a similar problem (stock menu options missing, like encryption)?
Thanks!
Thanks!
