Summary:
Screenshots:
Main Screen:
Settings Screen:
Some motivation:Simple tool for professors and teachers to keep track of point deductions as you grade papers and exams. Calculate grade as you go and save time by not doing a post grade tally."
More info + QR Barcode: Apps Android For AcademicsThis app is a simple tool professors can use while grading assignments/tests. The idea is simple: when you take points off a students paper, you press the associated button that corresponds to that value you took off.
For example, suppose you have a test out of 100 points. As you are going through the assignment, the student loses 3 points on a question. On the app, you press the -3 button, and the value at the top of the app will change from 100 to 97. Why is this helpful? When you are finished grading the paper, you will no longer need to go back and count every point deduction! This might not seem like a lot, but when you have 100 papers to grade, it comes in handy!
Screenshots:
Main Screen:
Settings Screen:
