Apps Android ImageView Visibility help
I have an ImageView object, x, loaded into my application. I want to toggle its visibility by clicking a button in the same activity. I have this code:
if(x.getVisibility() == INVISIBLE)
x.setVisibility(VISIBLE);
elseif(x.getVisibility() == VISIBLE)
x.setVisibility(INVISIBLE);
The default visibility setting is set to VISIBLE. When I click the button, the image won't vanish. Does anyone know how to fix this?
Hello,
In your Layout xml file you can give the image visibility with "android:visibility="invisible" "
And in your .java file
x.setVisibility(1); // it will be visible if set to 0 invisible
Good luck
Thanks
Vinay Guntaka
