Baldilocks
Android Expert
Why would I want to only select part of the photo? NO other phone asks me to only use part of a wallpaper.
I have a ton of 480 x 800 wallpapers and they all look like crap if used AS a wallpaper. They looked perfect on my iPhone(s).
Here, I will show you.
In photo gallery:
Setting wallpaper: (You can only make the box so big, it's a very illogical system. I want to use the WHOLE wallpaper.)
Set as wallpaper:
It's very frustrating that the great Android can't do this one simple function that even my Moto Razr V3 still does perfectly.
Before you reply.
1. I have scrollable wallpapers turned OFF thru Launcher Pro. I have no need for wallpaper that moves.
2. Every other phone EVER made has no problem with displaying wallpapers that are already at the correct resolution for the screen.
Is there something I am missing? Is there a hack or application that will let me use my own 480 x 800 wallpapers they way they were meant to be used??
In photo gallery:
Set as wallpaper:
Before you reply.
