Android Lollipop Update Alert for Micromax CANVAS users
Ankush Das
Those who own, Micromax canvas phone series will be getting the lollipop update irrespective of being the budget phones most of it. Xpress and Unite 2 has got the manual upgrade. While others will be getting soon. Keep yourself in touch with the nearest customer care for the manual upgrade to Lollipop 5.0
I have it but I personally suggest you to not upgrade to lollipop now because its getting so much problems.
Well, I am having no problem at all. I would recommend to upgrade to Lollipop its way smoother. Performance is better. Battery lasts longer. And at last it is LOLLIPOP which let's you use the whole INTERNAL STORAGE to install apps i.e up to 4GB.
And less bloatware.
