Android O support for Picture in Picture
krishnan
Hi All
I have searched a lot but couldn't get satisfactory solution. What I am looking for is how to enable/try PIP in Android O (Developer Preview 3). I read that the option to try PIP (System->System UI Tuner-> ...) removed on Android O build ODP3. I am not posting about the APIs (PIP APIs is till there) but about the button which we could use to use PIP.
I am using Google Pixel C with Android O build version ODP3. I upgraded from Android Nougat to Android O, over the air with Android Beta program.
Would really appreciate if any one could give me some points to try PIP on Android O DP3.
Krishnan​
