Android OS for Cyclone Nano Plus box?
Darren M
Hi all,
To do what I describe below will be a first for me, with this type of device.
I have a Cyclone Nano Slim Plus box, which came preloaded with the Linux OS on it. I want to pin hole reset the box and delete the OS, then install a suitable Android version on it.
Would anyone be kind enough to point me in the right direction where I can find the correct Android OS version for this box?
Also, can I use a USB stick to install the new OS, or do I need a micro SD card? Obviously the box has a few different connections, but I'm guessing not all will interact with the box's root directory?
Hi Darren,
Any news with this ?
I have same box. Also mate could you confirm if yours has an internal back up batt ?
Mine seems to be missing. In xbmc under settings it shows battery level 0% had a look inside and no battery installed.
I want to upgrade firmware to enable me to install showbox.
Can anyone help ?
Thank you.
