Android Questions Need To Answer it
Max Bayne
hiii every body
i entered quiz and need to test my answers for this questions so please give me question number and the correct answer
thanks
Question 01
Question 02
Question 03
Question 04
Question 05
Question 06
Question 07
Question 08
thanks ....
thanks for all
but this is not my home work
this is quiz that i entered it and have some questions that i need to sure if my answer is correct or not, so i get here to ask experts
i can put random answers to answer your question but i need the correct answer
But you said you did have the answers and only wanted them to be checked...
I still think you should do your own homework though. Even if it's not for a formal class you won't grow your knowledge by getting the answers from others... You'll learn and win by doing it yourself
Could even be for a job pre-interview. It's very technical.
So you are saying you don't have a clue?
What is this quiz for anyway? From your posts it's something that's important to you, but if it's important surely it's supposed to test your knowledge, rather than your ability to get someone to give you the answers. And if you can't answer the questions at all (which this post implies) you won't learn anything just from being told the answers either.
(Disclosure: I'm an academic, so I am interested in my students understanding what they're doing rather than just trying to memorize possible answers. Hence asking for solutions to a quiz but not being willing to discuss what you know triggers professional reservations in me ;))
It does look like an interesting quiz though.. can you let us know where it is so that we can enter?
This is the reason I tend not to provide complete code answers in the Android Dev forum. Because some people have really limited knowledge, and spoon feeding them everything wouldn't contribute much in terms of improving their understanding. Instead I try to steer them in the right direction, often with help from web resources, or provide small snippets of code to illustrate a point. In my view there is no better way to understand something, than to work through a problem and find the answer yourself.
So it may seem like we're being a bit harsh on the OP here, but it does kind of look like a technical test has been set, with the aim of learning. Especially as they aren't really giveaway questions either, and need some thought to answer them.
