A Unique Android Problem
I have a Huawei Honor 4c (CHM-U01) .
About two years ago , the device had a problem with its power circuit .
Since then , it has been unable to run any audio or video
Problems with the device :
If an audio or video is played , the device crashes and reboots immediately .
This includes touch sounds , notification sounds , app sounds , sounds associated with calling , playing a video , video ads in apps etc... Audio recorder , voice input , text to speech , inserting a device in the audio jack also cause a reboot .
The device was still stock when his problem started . It has since been rooted and has been upgraded to Android 6.0
What the device can still do
Sms , WiFi , Bluetooth and all apps work ( unless they have audio or video )
Basically anything without audio/video input/output works fine .
Taking pictures with camera works but making a video = reboot
Messaging apps can also be used by turning off their sounds from their settings.
By muting the device sounds and using adaway to block the video ads , most apps works normally .
But apps that have sounds on by default do not work . even if there is an option to turn off sounds when app starts ,, it can not be used since the device reboots as soon as the app is launched .
Deleted all user and system audio files and audio apps .
But often while using a browser to view web pages an auto playing video reboots the phone
can't use apps/games that come with audio turned on
Is there any way to completely remove sound output and audio/video players in android ?
