Help Android Recovery loop
A
Android Question
Guest
Hello, I'm in a sticky situation with my Alcatel One Touch Fierce 2, I had a firmware update called 15001 for a while and I finally decided to unroot my phone through the means of Kingroot. And I factory reset my phone so I can have stock android and I was downloading the update but then it said downloaded failed/aborted and every time I boot up my device it reboots and goes into recovery mode with the message no command at the bottom. I'm thinking my device is soft-bricked. Also, something appears to be a Dead android bot with the center open with a Red triangle with an exclamation mark. Like what was said earlier I tried to select "Reboot system now" but it will go on a cycle of rebooting 2 times and going to recovery mode, and suggestions? My cell phone carrier is MetroPCS
