Hi,
I get invalid entry crc-32 for most package downloads using the Android Manager
Downloading Documentation for Android SDK, API 12, revision 1
Installing Documentation for Android SDK, API 12, revision 1
Unexpected Error installing 'Documentation for Android SDK, API 12, revision 1': java.lang.IllegalArgumentException: invalid entry crc-32
I did stop and retry around 3-4 times. However, I end up with the same problem. I also installed the JDK with latest Update 22.
I did search through the forum thread and did not find anything similar. Please pardon if its duplicate thread.
Thanks in advance.
Jerry
Thanks in advance.
Jerry
