Hi Guys! new here and im kinda stuck on a small issue. im working with google places on a small application m making and i'm currently able to show 20 markers on the map. I have a floating action button on my map screen and I was just wondering if theres a way to store and call the next_page_token so that when the user clicks on the floating button then it would display the 20 markers from the next page. I have the following code: (Lines 40 to 74)
My JSONParser class:
Currently ive hardcoded the next_page_token into my code and it seems to work, but it only works once, any ideas on how i could call and retrieve it automatically using a variable?
Any info will be appreciated!
Thanks!
Code:
public class MapsActivity extends FragmentActivity implements LocationListener {
GoogleMap mMap;
double mLatitude = 0;
double mLongitude = 0;
HashMap<String, String> mMarkerPlaceLink = new HashMap<String, String>();
@Override
setContentView(R.layout.activity_maps);
// Obtain the SupportMapFragment and get notified when the map is ready to be used.
SupportMapFragment mapFragment = (SupportMapFragment) getSupportFragmentManager()
.findFragmentById(R.id.map);
mMap = mapFragment.getMap();
// Enabling MyLocation in Google Map
mMap.setMyLocationEnabled(true);
mMap.getUiSettings().setCompassEnabled(true);
mMap.getUiSettings().setZoomControlsEnabled(true);
// Getting LocationManager object from System Service
// LOCATION_SERVICE
LocationManager locationManager = (LocationManager) getSystemService(LOCATION_SERVICE);
// Creating a criteria object to retrieve provider
Criteria criteria = new Criteria();
// Getting the name of the best provider
String provider = locationManager.getBestProvider(criteria, true);
// Getting Current Location From GPS
Location location = locationManager.getLastKnownLocation(provider);
// onLocationChanged(location);
if (location != null) {
StringBuilder sb = new StringBuilder(
"https://maps.googleapis.com/maps/api/place/nearbysearch/json?");
sb.append("location=" + mLatitude + "," + mLongitude);
sb.append("&radius=1000");
sb.append("&key=PLACES_KEY");
// Creating a new non-ui thread task to download Google place json
// data
PlacesTask placesTask = new PlacesTask();
// Invokes the "doInBackground()" method of the class PlaceTask
placesTask.execute(sb.toString());
// Will display 20 more places returned form the next_page_token
FloatingActionButton fab = (FloatingActionButton) findViewById(R.id.fab_more);
fab.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View view) {
Snackbar.make(view, "Finding you some more places!", Snackbar.LENGTH_LONG)
.setAction("Action", null).show();
sb.append("pagetoken=" );
// data
* A method to download json data from url
private String downloadUrl(String strUrl) throws IOException {
String data = "";
InputStream iStream = null;
HttpURLConnection urlConnection = null;
try {
URL url = new URL(strUrl);
// Creating an http connection to communicate with url
urlConnection = (HttpURLConnection) url.openConnection();
// Connecting to url
urlConnection.connect();
// Reading data from url
iStream = urlConnection.getInputStream();
BufferedReader br = new BufferedReader(new InputStreamReader(
iStream));
StringBuffer sb = new StringBuffer();
String line = "";
while ((line = br.readLine()) != null) {
sb.append(line);
data = sb.toString();
Log.d("data", "json response: " + data);
br.close();
} catch (Exception e) {
Log.d("Exception while downloading url", e.toString());
} finally {
iStream.close();
urlConnection.disconnect();
return data;
* A class, to download Google Places
private class PlacesTask extends AsyncTask<String, Integer, String> {
String data = null;
// Invoked by execute() method of this object
@Override
protected String doInBackground(String... url) {
try {
data = downloadUrl(url[0]);
Log.d("Background Task", e.toString());
return data;
// Executed after the complete execution of doInBackground() method
@Override
protected void onPostExecute(String result) {
ParserTask parserTask = new ParserTask();
// Start parsing the Google places in JSON format
// Invokes the "doInBackground()" method of the class ParseTask
parserTask.execute(result);
* A class to parse the Google Places in JSON format
private class ParserTask extends
AsyncTask<String, Integer, List<HashMap<String, String>>> {
JSONObject jObject;
@Override
protected List<HashMap<String, String>> doInBackground(
String... jsonData) {
List<HashMap<String, String>> places = null;
PlaceJSONParser placeJsonParser = new PlaceJSONParser();
try {
jObject = new JSONObject(jsonData[0]);
/** Getting the parsed data as a List construct */
places = placeJsonParser.parse(jObject);
Log.d("Exception", e.toString());
return places;
@Override
protected void onPostExecute(List<HashMap<String, String>> list) {
// Clears all the existing markers
mMap.clear();
for (int i = 0; i < list.size(); i++) {
// Creating a marker
MarkerOptions markerOptions = new MarkerOptions();
// Getting a place from the places list
HashMap<String, String> hmPlace = list.get(i);
// Getting latitude of the place
double lat = Double.parseDouble(hmPlace.get("lat"));
// Getting longitude of the place
double lng = Double.parseDouble(hmPlace.get("lng"));
// Getting name
String name = hmPlace.get("place_name");
String vicinity = hmPlace.get("vicinity");
LatLng latLng = new LatLng(lat, lng);
// Setting the position for the marker
markerOptions.position(latLng);
markerOptions.title(name);
markerOptions.snippet(vicinity);
// Placing a marker on the touched position
Marker m = mMap.addMarker(markerOptions);
// Linking Marker id and place reference
mMarkerPlaceLink.put(m.getId(), hmPlace.get("reference"));
@Override
public void onLocationChanged(Location location) {
mLatitude = location.getLatitude();
mLongitude = location.getLongitude();
LatLng latLng = new LatLng(mLatitude, mLongitude);
mMap.moveCamera(CameraUpdateFactory.newLatLng(latLng));
mMap.animateCamera(CameraUpdateFactory.zoomTo(15));
@Override
public void onStatusChanged(String provider, int status, Bundle extras) {
@Override
public void onProviderEnabled(String provider) {
@Override
public void onProviderDisabled(String provider) {
Code:
public class PlaceJSONParser {
/** Receives a JSONObject and returns a list */
public List<HashMap<String,String>> parse(JSONObject jObject){
JSONArray jPlaces = null;
try {
/** Retrieves all the elements in the 'places' array */
jPlaces = jObject.getJSONArray("results");
} catch (JSONException e) {
e.printStackTrace();
/** Invoking getPlaces with the array of json object
* where each json object represent a place
return getPlaces(jPlaces);
private List<HashMap<String, String>> getPlaces(JSONArray jPlaces){
int placesCount = jPlaces.length();
List<HashMap<String, String>> placesList = new ArrayList<HashMap<String,String>>();
HashMap<String, String> place = null;
/** Taking each place, parses and adds to list object */
for(int i=0; i<placesCount;i++){
try {
/** Call getPlace with place JSON object to parse the place */
place = getPlace((JSONObject)jPlaces.get(i));
placesList.add(place);
return placesList;
/** Parsing the Place JSON object */
private HashMap<String, String> getPlace(JSONObject jPlace){
HashMap<String, String> place = new HashMap<String, String>();
String placeName = "-NA-";
String vicinity = "-NA-";
String latitude="";
String longitude="";
String reference="";
try {
// Extracting Place name, if available
if(!jPlace.isNull("name")){
placeName = jPlace.getString("name");
// Extracting Place Vicinity, if available
if(!jPlace.isNull("vicinity")){
vicinity = jPlace.getString("vicinity");
latitude = jPlace.getJSONObject("geometry").getJSONObject("location").getString("lat");
longitude = jPlace.getJSONObject("geometry").getJSONObject("location").getString("lng");
reference = jPlace.getString("reference");
place.put("place_name", placeName);
place.put("vicinity", vicinity);
place.put("lat", latitude);
place.put("lng", longitude);
place.put("reference", reference);
return place;
Thanks!
