So I have a GoClever TERRA 10.1 (http://www.goclever.com/si/products,c1/tablet,c5/archive,c98/terra-101,a248.html) and out of the blue it woudn't start (stuck on android loading screen). Now' I've taken it apart and checked the hardware (which is OK, nothing's burned or such) and now I've tried formatting it and it's stuck (as in the bar that shows progress is still, frozen).. I dont have any sd cards at hand so any options that don't need an sd card (perhaps flashing it from PC?) would be, for now, better
Thanks!
Ps: the processor is quite warm/hot so it's definitely doing something.. is it possible the memory unit itself is corrupted? if so, is it a possible fix?;
Also I've somehow managed to wipe cache, media and data (so format was succesful).. still stuck on android logo though.. quite a bummer
Thanks!
