Gregary Boyles
I have tried using log.d("...", "....") but my debug output does not appear in android monitor logcat.
So what else do I need to do to view my debug output?
bjectInputStream;
bjectOutputStream;package com.example.greg.irrigationcontroller;
import android.app.Application;
import android.content.res.Configuration;
import java.util.Calendar;
import android.util.Log;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io_ObjectInputStream;
import java.io_ObjectOutputStream;
import java.util.ArrayList;
* Created by Greg on 24/09/2017.
public class CIrrigationApplication extends Application
/** Class representing an individual watering time and duration. */
public class CWateringTime
/** Constructor */
public CWateringTime()
/** Constructor */
public CWateringTime(final int nHour, final int nMinutes, final int nOnTime)
m_nHour = nHour;
m_nMinutes = nMinutes;
m_nOnTime = nOnTime;
/** Dump irrigation settings to event log window */
protected void Dump()
Log.d("", String.valueOf(m_nHour) + ":" + String.valueOf(m_nMinutes) + "(" + String.valueOf(m_nOnTime) + ")");
/** Implentation */
public int m_nHour, m_nMinutes, m_nOnTime;
/** Class representing an individual watering day list of watering times. */
public class CWateringDay
/** Constructor */
public CWateringDay()
m_arrayWateringTimes = new ArrayList<CWateringTime>();
public CWateringDay(final int nDOM, final int nMonth)
m_nDOM = nDOM;
m_nMonth = nMonth;
/** Add a new watering time to the watering time this watering day */
public void AddWateringTime(final int nHour, final int nMinute, final int nOnTime)
m_arrayWateringTimes.add(new CWateringTime(nHour, nMinute, nOnTime));
Log.d("", String.valueOf(m_nDOM) + "/" + String.valueOf(m_nMonth) + " => ");
CWateringTime WateringTime = new CWateringTime();
for (int nI = 0; nI < m_arrayWateringTimes.size(); nI++)
WateringTime = m_arrayWateringTimes.get(nI);
WateringTime.Dump();
/** Implentation */
public int m_nDOM, m_nMonth;
public ArrayList<CWateringTime> m_arrayWateringTimes;
/** Class representing an individual station with a list of watering days. */
public class CStation
/** Constructor */
public CStation(final int nStation)
m_nStation = nStation;
m_bActive = false;
m_arrayWateringDays = new ArrayList<CWateringDay>();
Log.d("m_bActive = ", String.valueOf(m_bActive));
Log.d("m_nStation = ", String.valueOf(m_nStation));
CWateringDay WateringDay = new CWateringDay();
for (int nI = 0; nI < m_arrayWateringDays.size(); nI++)
WateringDay = m_arrayWateringDays.get(nI);
WateringDay.Dump();
/** Implentation */
public int m_nStation;
public boolean m_bActive;
public ArrayList<CWateringDay> m_arrayWateringDays;
/** Constructor */
public CIrrigationApplication()
m_dateFrom = Calendar.getInstance();
m_dateTo = Calendar.getInstance();
m_timeFrom =Calendar.getInstance();
m_timeTo = Calendar.getInstance();
// Called by the system when the device configuration changes while your component is running.
// Overriding this method is totally optional!
@override
public void onConfigurationChanged(Configuration newConfig)
super.onConfigurationChanged(newConfig);
// This is called when the overall system is running low on memory,
// and would like actively running processes to tighten their belts.
@override
public void onLowMemory()
super.onLowMemory();
/** Overrides */
@override
public void onCreate()
super.onCreate();
for (int nI = 0; nI < m_nMaxStations; nI++)
m_arrayStations[nI] = new CStation(nI + 1);
GetSettings();
Dump();
/** Save irrigation settings from the data file */
protected void PutSettings()
try
FileOutputStream file = new FileOutputStream(m_strDataFileName);
ObjectOutputStream stream = new ObjectOutputStream(file);
stream.writeObject(m_arrayStations[m_nStation].m_arrayWateringDays);
stream.close();
file.close();
catch(IOException ioe)
System.out.println(ioe.getMessage());
return;
/** Read irrigation settings from the data file */
protected void GetSettings()
try
FileInputStream file = new FileInputStream(m_strDataFileName);
ObjectInputStream stream = new ObjectInputStream(file);
m_arrayStations[m_nStation].m_arrayWateringDays = (ArrayList<CWateringDay>) stream.readObject();
stream.close();
file.close();
catch (IOException ioe)
return;
catch (ClassNotFoundException ioe)
return;
m_arrayStations[nI].Dump();
/** Add a new watering day to the array and return its index */
public int AddWateringDay(final int nDOM, final int nMonth)
if ((m_nStation >= 0) && (m_nStation < m_nMaxStations))
m_arrayStations[m_nStation].m_arrayWateringDays.add(new CWateringDay(nDOM, nMonth));
return m_arrayStations[m_nStation].m_arrayWateringDays.size() - 1;
return -1;
/** Add a new watering time to the watering day specified by nI */
public void AddWateringTime(final int nI, final int nHour, final int nMinute, final int nOnTime)
if ((nI >= 0) && (nI < m_arrayStations[m_nStation].m_arrayWateringDays.size()))
CWateringDay WateringDay = m_arrayStations[m_nStation].m_arrayWateringDays.get(nI);
WateringDay.AddWateringTime(nHour, nMinute, nOnTime);
m_arrayStations[m_nStation].m_arrayWateringDays.set(nI, WateringDay);
public void AddWateringTime(final int nI, CWateringTime WateringTime)
AddWateringTime(nI, WateringTime.m_nHour, WateringTime.m_nMinutes, WateringTime.m_nOnTime);
public void ClearCurrentStationWateringDays()
m_arrayStations[m_nStation].m_arrayWateringDays.clear();
public boolean SettingsEmpty()
return (m_nStation >= 0) && (m_nStation < m_nMaxStations) && (m_arrayStations[m_nStation].m_arrayWateringDays.size() > 0);
/** Global data. */
public Calendar m_dateFrom, m_dateTo, m_timeFrom, m_timeTo;
public int m_nStation, m_nFreq1, m_nFreq2, m_nHourFreq, m_nOnTime;
public final int m_nMaxStations = 24;
protected CStation[] m_arrayStations = new CStation[m_nMaxStations];
protected String m_strDataFileName = "irrigation.dat";
