Hello! I am currently working on acheiving certain tasks depending on the data received from a Bluetooth module using the input buffer. Currently I am trying to play a sound depending on the input using MediaPlayer.Create, but only seems to work when I have the device plugged in and hit "Apply Changes and Restart Activity." It does not seem to work if I were to just open the app and test, only after going through the process stated before. Is there a better way of reading the inputstream and handling that data? Is there also a better way to go about how I am playing a sound in the run() function of the ConnectedThread thread? This is my current code. I am also thinking of switching from MediaPlayer to SoundPool because I would like to play multiple sounds simultaneously, would that also be a good option?
I feel like the problem I have might be the way I am passing the context to the MediaPlayer in the ConnectedThread thread, but I'm honestly not too sure because i just started learning kotlin. What other options do I have for evaluating the bytearray being sent from the Bluetooth?
Code:
class ControlActivity: AppCompatActivity() {
companion object {
var m_myUUID: UUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB")
var m_bluetoothSocket: BluetoothSocket? = null
lateinit var m_progress: ProgressDialog
lateinit var m_bluetoothAdapater: BluetoothAdapter
var m_isConnected: Boolean = false
lateinit var m_address: String
private const val TAG = "MY_APP_DEBUG_TAG"
const val MESSAGE_READ: Int = 0
const val MESSAGE_WRITE: Int = 1
const val MESSAGE_TOAST: Int = 2
private lateinit var handler: Handler
var mMediaPlayer: MediaPlayer? = null
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.control_layout)
m_address = intent.getStringExtra(SettingsActivity.EXTRA_ADDRESS)!!
ConnectToDevice(this).execute()
control_led_on.setOnClickListener { sendCommand("1") }
control_led_off.setOnClickListener { sendCommand("0") }
control_led_disconnect.setOnClickListener { disconnect() }
private fun sendCommand(input: String){
if (m_bluetoothSocket != null){
try {
m_bluetoothSocket!!.outputStream.write(input.toByteArray())
Log.i("data", "sending..")
} catch (e: IOException) {
e.printStackTrace()
Log.i("data", "couldn't send")
return
private fun disconnect(){
try {
m_bluetoothSocket!!.close()
m_bluetoothSocket = null
m_isConnected = false
e.printStackTrace()
finish()
private class ConnectedThread(private val mmSocket: BluetoothSocket?, c : Context) : Thread() {
private val mmBuffer: ByteArray = ByteArray(10) // mmBuffer store for the stream
var context: Context
init{
this.context = c
override fun run() {
var numBytes: Int = 0// bytes returned from read()
//var begin: Int = 0
// Keep listening to the InputStream until an exception occurs.
while (true) {
// Read from the InputStream.
try {
numBytes =
mmSocket!!.inputStream.read(mmBuffer, numBytes, mmBuffer.size - numBytes)
Log.d(TAG, "Input stream was disconnected", e)
break
playNote(context)
println(numBytes)
println(String(mmBuffer))
fun playNote(c: Context) {
if (mMediaPlayer == null) {
mMediaPlayer = MediaPlayer.create(c, R.raw.c3)
mMediaPlayer!!.start()
} else if (mMediaPlayer != null) {
mMediaPlayer!!.stop()
mMediaPlayer!!.release()
mMediaPlayer = null
} else mMediaPlayer!!.start()
private class ConnectToDevice(c: Context) : AsyncTask<Void, Void, String>(){
private var connectSuccess: Boolean = true
private val context: Context
init {
this.context = c
override fun onPreExecute() {
super.onPreExecute()
m_progress = ProgressDialog.show(context, "Connecting...", "please wait")
override fun doInBackground(vararg p0: Void?) : String? {
try {
if (m_bluetoothSocket == null || !m_isConnected){
m_bluetoothAdapater = BluetoothAdapter.getDefaultAdapter()
val device: BluetoothDevice = m_bluetoothAdapater.getRemoteDevice(m_address)
m_bluetoothSocket = device.createInsecureRfcommSocketToServiceRecord(m_myUUID)
BluetoothAdapter.getDefaultAdapter().cancelDiscovery()
m_bluetoothSocket!!.connect()
} catch (e: IOException){
connectSuccess = false
e.printStackTrace()
return null
override fun onPostExecute(result: String?) {
super.onPostExecute(result)
if(!connectSuccess){
Log.i("data", "couldn't connect")
} else {
m_isConnected = true
var connectedthread= ConnectedThread(m_bluetoothSocket, context)
connectedthread.start()
Log.i("data", "connected")
m_progress.dismiss()
