noeqplease
Hi,
I am new to software development.
Have been working in Android Studio slowly but getting somewhere, until yesterday.
I had to install the "Intel Hardware Acceleration" package, in order to be able to run emulators within my Apple laptop. Once I did this, it worked for a time.
Then, I got the following message:
NOTE: This project contains Java compilation errors, which can cause rendering failures for custom views.
Fix compilation problems first.
The following classes could not be instantiated:
- android.support.v7.internal.widget.ActionBarOverlayLayout
Exception details
java.lang.NoClassDefFoundError: Could not initialize class.
etc...
What does this even mean? I had the simplest of software "apps" : one full size image button, which I was in the middle of learning how to make it play one small sound sample (doing this in Android, this is horrifically complicated, BTW) And the preview had the image button displayed correctly, and everything was "compiling" properly.
This is horrible. I cannot work in ANY new projects: I created new projects, empty ones, ones from templates, ones with lower Android versions, all sorts of things, and it gives me this error EVERY TIME.
Thank you for any help you can give me. I am just too confused by this sudden error. I have no idea why it is happening.
Here is the "stack" :
java.lang.ClassNotFoundException: android.support.v7.appcompat.R$attr
at org.jetbrains.android.uipreview.ModuleClassLoader.load(ModuleClassLoader.java:127)
at com.android.tools.idea.rendering.RenderClassLoader.findClass(RenderClassLoader.java:53)
at org.jetbrains.android.uipreview.ModuleClassLoader.findClass(ModuleClassLoader.java:84)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at android.support.v7.internal.widget.ActionBarOverlayLayout.<clinit>(ActionBarOverlayLayout.java:149)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.jetbrains.android.uipreview.ViewLoader.createNewInstance(ViewLoader.java:413)
at org.jetbrains.android.uipreview.ViewLoader.loadView(ViewLoader.java:105)
at com.android.tools.idea.rendering.LayoutlibCallback.loadView(LayoutlibCallback.java:177)
at android.view.BridgeInflater.loadCustomView(BridgeInflater.java:214)
at android.view.BridgeInflater.createViewFromTag(BridgeInflater.java:142)
at android.view.LayoutInflater.inflate(LayoutInflater.java:482)
at android.view.LayoutInflater.inflate(LayoutInflater.java:414)
at com.android.layoutlib.bridge.bars.BridgeActionBar.<init>(BridgeActionBar.java:84)
at com.android.layoutlib.bridge.bars.AppCompatActionBar.<init>(AppCompatActionBar.java:56)
at com.android.layoutlib.bridge.impl.RenderSessionImpl.createActionBar(RenderSessionImpl.java:1691)
at com.android.layoutlib.bridge.impl.RenderSessionImpl.inflate(RenderSessionImpl.java:362)
at com.android.layoutlib.bridge.Bridge.createSession(Bridge.java:321)
at com.android.ide.common.rendering.LayoutLibrary.createSession(LayoutLibrary.java:350)
at com.android.tools.idea.rendering.RenderTask$2.compute(RenderTask.java:497)
at com.android.tools.idea.rendering.RenderTask$2.compute(RenderTask.java:485)
at com.intellij.openapi.application.impl.ApplicationImpl.runReadAction(ApplicationImpl.java:894)
at com.android.tools.idea.rendering.RenderTask.createRenderSession(RenderTask.java:485)
at com.android.tools.idea.rendering.RenderTask.render(RenderTask.java:590)
at org.jetbrains.android.uipreview.AndroidLayoutPreviewToolWindowManager.doRender(AndroidLayoutPreviewToolWindowManager.java:644)
at org.jetbrains.android.uipreview.AndroidLayoutPreviewToolWindowManager.access$1700(AndroidLayoutPreviewToolWindowManager.java:79)
at org.jetbrains.android.uipreview.AndroidLayoutPreviewToolWindowManager$7$1.run(AndroidLayoutPreviewToolWindowManager.java:586)
at com.intellij.openapi.progress.impl.CoreProgressManager$2.run(CoreProgressManager.java:152)
at com.intellij.openapi.progress.impl.CoreProgressManager.registerIndicatorAndRun(CoreProgressManager.java:452)
at com.intellij.openapi.progress.impl.CoreProgressManager.executeProcessUnderProgress(CoreProgressManager.java:402)
at com.intellij.openapi.progress.impl.ProgressManagerImpl.executeProcessUnderProgress(ProgressManagerImpl.java:54)
at com.intellij.openapi.progress.impl.CoreProgressManager.runProcess(CoreProgressManager.java:137)
at org.jetbrains.android.uipreview.AndroidLayoutPreviewToolWindowManager$7.run(AndroidLayoutPreviewToolWindowManager.java:581)
at com.intellij.util.ui.update.MergingUpdateQueue.execute(MergingUpdateQueue.java:320)
at com.intellij.util.ui.update.MergingUpdateQueue.execute(MergingUpdateQueue.java:310)
at com.intellij.util.ui.update.MergingUpdateQueue$2.run(MergingUpdateQueue.java:254)
at com.intellij.util.ui.update.MergingUpdateQueue.flush(MergingUpdateQueue.java:269)
at com.intellij.util.ui.update.MergingUpdateQueue.flush(MergingUpdateQueue.java:227)
at com.intellij.util.ui.update.MergingUpdateQueue.run(MergingUpdateQueue.java:217)
at com.intellij.util.concurrency.QueueProcessor.runSafely(QueueProcessor.java:238)
at com.intellij.util.Alarm$Request$1.run(Alarm.java:351)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:439)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:695)
Exception details
etc...
