ANDROID STUDIO TELNET DISCONNECT PROBLEM
Hi, my code do the telnet socket disconnection ok, however only after clicking send button, it seems onclick send button calls the disconnect routine.
Follow below the code.
public class MainActivity extends AppCompatActivity {
String host="192.168.0.100",mensaje;
int port=23;
private final String TAG = getClass().getSimpleName();
private Toast fastToast;
// AsyncTask object that manages the connection in a separate thread
WiFiSocketTask wifiTask = null;
// UI elements
EditText editSend;
Button buttonSend;
ToggleButton condesc;
private static TextView inputStreamTextView;
private static TextView outputStreamTextView;
@override
setContentView(R.layout.activity_main);
setRequestedOrientation(ActivityInfo.SCREEN_ORIENTATION_PORTRAIT); //orientacion horizontal
getWindow().setSoftInputMode(WindowManager.LayoutParams.SOFT_INPUT_STATE_ALWAYS_HIDDEN); //deshabilita teclado al iniciar aplicacion
inputStreamTextView = (TextView) findViewById(R.id.inputStreamTextView);
inputStreamTextView.setMovementMethod(new ScrollingMovementMethod());
outputStreamTextView = (TextView)findViewById(R.id.outputStreamTextView);
outputStreamTextView.setMovementMethod(new ScrollingMovementMethod());
editSend = (EditText)findViewById(R.id.editSend);
buttonSend = (Button)findViewById(R.id.buttonSend);
condesc = (ToggleButton)findViewById(R.id.condesc);
fastToast = Toast.makeText(this,"", Toast.LENGTH_SHORT);
void toastFast(String str) {
fastToast.setText(str);
fastToast.show();
* Helper function, print a status to both the UI and program log.
void setStatus(String s) {
Log.v(TAG, s);
//textStatus.setText(s);
public void ToggleButtonConectOnClick(View view){
if(condesc.isChecked()){
conectar();
}else{
desconectar();
* Try to start a connection with the specified remote host.
public void conectar() {
if(wifiTask != null) {
setStatus("ya esta Conectado!");
toastFast("ya esta Conectado!");
return;
try {
// Get the remote host from the UI and start the thread
/// String host = editTextAddress.getText().toString();
// int port = Integer.parseInt(editTextPort.getText().toString());
// Start the asyncronous task thread
setStatus("Conectando...");
wifiTask = new WiFiSocketTask(host, port);
wifiTask.execute();
} catch (Exception e) {
e.printStackTrace();
setStatus("Puerto o direccion invalidas!");
toastFast("Puerto o direccion invalidas!");
* Disconnect from the connection.
public void desconectar() {
if(wifiTask == null) {
setStatus("Desconectado!");
toastFast("Desconectado!");
return;
wifiTask.disconnect();
setStatus("Desconectando...");
toastFast("Desconectando...");
* Invoked by the AsyncTask when the connection is successfully established.
private void connected() {
setStatus("Conectado.");
toastFast("Conectado.");
buttonSend.setEnabled(true);
* Invoked by the AsyncTask when the connection ends..
private void disconnected() {
setStatus("Desconectado.");
toastFast("Desconectado.");
//buttonSend.setEnabled(false);
// inputStream.setText("");
// textTX.setText("");
wifiTask = null;
private void colorea(){
if (android.os.Build.VERSION.SDK_INT >= android.os.Build.VERSION_CODES.N) {
inputStreamTextView.append(Html.fromHtml(mensaje,Html.FROM_HTML_MODE_LEGACY));
} else {
inputStreamTextView.append(Html.fromHtml(mensaje));
inputStreamTextView.append(""+'\n');
* Invocado AsyncTask cuando se recibe una nueva linea.
private void gotMessage(String msg) {
inputStreamTextView.append(msg+'\n');
Log.v(TAG, "[RX] "+msg);
* Send the message typed in the input field using the AsyncTask.
@SuppressLint("ResourceAsColor")
public void sendButtonPressed(View v) {
if(wifiTask == null) return;
String msg = editSend.getText().toString();
if(msg.length() == 0) return;
wifiTask.sendMessage(msg);
outputStreamTextView.append(msg+'\n');
mensaje="<font color=#0000FF>Sent --> </font>"+msg; //colorear en azul
colorea();;
Log.v(TAG, "[TX] " );
* AsyncTask that connects to a remote host over WiFi and reads/writes the connection
* using a socket. The read loop of the AsyncTask happens in a separate thread, so the
* main UI thread is not blocked. However, the AsyncTask has a way of sending data back
* to the UI thread. Under the hood, it is using Threads and Handlers.
public class WiFiSocketTask extends AsyncTask<Void, String, Void> {
// Location of the remote host
String address;
int port;
// Special messages denoting connection status
private static final String PING_MSG = "SOCKET_PING";
private static final String CONNECTED_MSG = "SOCKET_CONNECTED";
private static final String DISCONNECTED_MSG = "SOCKET_DISCONNECTED";
Socket socket = null;
BufferedReader inStream = null;
OutputStream outStream = null;
// Signal to disconnect from the socket
private boolean disconnectSignal = false;
// Socket timeout - close if no messages received (ms)
private int timeout = 5000;
// Constructor
WiFiSocketTask(String address, int port) {
this.address = address;
this.port = port;
* Main method of AsyncTask, opens a socket and continuously reads from it
@override
protected Void doInBackground(Void... arg) {
try {
// Open the socket and connect to it
socket = new Socket();
socket.connect(new InetSocketAddress(address, port), timeout);
// Get the input and output streams
inStream = new BufferedReader(new InputStreamReader(socket.getInputStream()));
outStream = socket.getOutputStream();
// Confirm that the socket opened
if(socket.isConnected()) {
// Make sure the input stream becomes ready, or timeout
long start = System.currentTimeMillis();
while(!inStream.ready()) {
long now = System.currentTimeMillis();
if(now - start > timeout) {
Log.e(TAG, "Input stream timeout, disconnecting!");
disconnectSignal = true;
break;
} else {
Log.e(TAG, "Socket did not connect!");
// Read messages in a loop until disconnected
while(!disconnectSignal) {
// Parse a message with a newline character
String msg = inStream.readLine();
// Send it to the UI thread
publishProgress(msg);
Log.e(TAG, "Error in socket thread!");
// Send a disconnect message
publishProgress(DISCONNECTED_MSG);
// Once disconnected, try to close the streams
try {
if (socket != null) socket.close();
if (inStream != null) inStream.close();
if (outStream != null) outStream.close();
return null;
* This function runs in the UI thread but receives data from the
* doInBackground() function running in a separate thread when
* publishProgress() is called.
@override
protected void onProgressUpdate(String... values) {
String msg = values[0];
if(msg == null) return;
// Handle meta-messages
if(msg.equals(CONNECTED_MSG)) {
connected();
} else if(msg.equals(DISCONNECTED_MSG))
disconnected();
else if(msg.equals(PING_MSG))
// Invoke the gotMessage callback for all other messages
else
gotMessage(msg);
super.onProgressUpdate(values);
* Write a message to the connection. Runs in UI thread.
public void sendMessage(String data) {
try {
outStream.write(data.getBytes());
outStream.write(0x0d);
outStream.write(0x0a);
* Set a flag to disconnect from the socket.
public void disconnect() {
