jtintle
Member
Found a way to launch the built in recovery,
With the device powered down,
Press and hold the Up volume, down volume and the power button until you see the android.
Options allowed are
reboot system now
apply update from external storage
wipe data/factory reset
wipe cache partition
apply update from cache
thanks to metrophonerepair.com for pointing it out
I don't know if it is helpful but I guess it could help if you get locked out of your phone to do a factory reset
Options allowed are
reboot system now
