Android T95 tv box
Tyson457
We've had this tv box for a couple months now. As soon as we got the box i installed kodinolimits build on it and its worked great. Well tonight i turned the box on and it was just the basic kodi screen so i went ahead and tried to install nolimits again but it keeps saying cannot install from zip. I have uninstalled kodi jarvis completely off the box and thought maybe try and install krypton 17. I get the app installed and go to add my build to it and same problem "cannot install from zip file".the box is a T95 if anyone can help with this problem it would be much appreciated. Thank you
Yes sir it was the newest version of nolimits and everything was working great until tonight. Thanks for your reply im gonna go do some reading see if i can get it to work. Again thank you
Those are the exact steps i follow to install it but when i go to install from zip than kodi than nolimits wizard it will not enable it instead it says unable to install from zip file.
