Hi, I'm new to the forum & XBMC/KODI in general, will try to give as much detail as possible.
Using our XBMC (QUAD CORE HD HP CAMERA Android TV Box Model: CS918S on the back it says OTT TV BOX 2GB RAM 16GB ROM) for months generally problem free on our Sony TV model: KDL-46EX500 (LCD i believe)
Got a new to us Samsung Plasma TV model: PN50A450PID so we wanted to see if the XBMC would work on it, no luck, just said "no signal" on any or all HDMI plug ins, ok so we give up....
Go to plug back into the SONY...Problem:
The box starts up goes through the initial "XBOC" rotating start screen then nothing!
the TV gives a message: Unsupported Signal. Please check the device output.
I would assume something from the plasma tv messed up the movie box, have no idea how to reset the box, hope someone can help. My husband is very upset, home sick & looking forward to watching some of his favorite shows/movies.
What other info can i give?
we are hooked up to Telus high speed internet & 25gb tv cable with wifi router.
Cheers,
Marneys
Cheers,
Marneys
