Hi guys. Just bought an android tv box off ebay to use with a qnap and xbmc. It works brilliantly streaming off the qnap but when the box is switched on it uses all the internet connection so no other device can access the internet. Does anyone know how to fix this. Cheers.
QNAP is a Chinese thing. Is there nothing in the settings about bandwidth? Failing that could be worth emailing them about it, see if they can suggest anything.
