Hi, I recently bought a JUSTOP Android 4 TV box from amazon. Being a recent new member, I can't specify a link but if search for JUSTOP android 4 box in Amazon, you'll know which one it is. It has a fair few reviews also.
Does anyone else have the same TV box? I had high hopes for it and it had some really good reviews from other people who had bought the product. I received it yesterday and everything seems to work well, very easy to plug into TV, played many different file formats, very well designed menus, fast and sits great behind my TV.
But since receiving it, I have had real problems with the WIFI disconnecting. At first I thought this was a hardware problem relating to the wireless receiver but after a few tests it was clear it was software related.
The WIFI ONLY disconnects every time I run an application (youtube,google play, browser, anything). If the box is in an idle state the WIFI stays connected with a strong signal. I have messed around with many different settings with the hope of being able to fix it but still no such luck. What is so frustrating is that everything else about the box is great and if the WIFI only worked properly I could see myself using this a lot due to turning my TV into a smart TV. It does come with a manual (with not so great english) which states about using PhoenixCardv306 to update it, although I wouldn't know where to find the update file for this as I'm surprised by how little information there is on this box over the internet (my fault, and starting to regret buying it).
Does anyone else own the same box or something similar and is there a solution to fix this?
