Hello. It is not typical issue. I have bought Xenic TVBox TVi7 with Android 4.0.4 ICS on board. Device is not rooted, and exploits what I have found to root it to run from TVi7 directly don't work. The device has 2 host USB ports. Is it possible to connect this device to my PC to run for example ADB commands? I tried with direct USB cable (male's type cable on both sides) and set in android configuration in USB tab, that USB will be used to Connect to PC but it doesn't work - my PC restarts for short time after make a cable connection. Nothing has fried for my luck. I can't use ADB in tcpip mode because I don't have root permissions to set it. I can't use any terminal apps for ADB commands from market directly on TVi7 because of root.
My device has builtin 2GB inner space treated as SD-CARD and is ignoring my external 16GB SD-CARD as a place for games and applications. None of apps like App2SD or Link2SD can move my apps to external SD-CARD because they just don't see it. Android sees both SD-CARDs properly (configuration menu).
I wanna to give a shot a command ADB shell pm setInstallLocation 2 but I can't do this now.
Any help will be appreciate.
