Hello.
I transferred music, sorted by iTunes, from my Macbook to my Samsung Galaxy S. Unfortunately, for a lot of the music albums, the standard music player shows <unknown> instead of the artist. It can read the album and title fields though. It seems like the problem is only with mp4-files. I tried a bunch of different music player apps, and some of them read more artists than others - none of them can read them all though.
I tried to convert ID3-tags in iTunes, but that did not change anything. I have tried to download different apps that should make you able to add metadata to your music files, but it does not seem to work.
What do you guys think? Should I convert all my music files to mp3 or another format than mp4 (that, I would really like to avoid) - or is there another solution?
I have searched all of the internet for a solution - so hopefully you can help me out.
Thanks in advance!
Thanks in advance!
