android-x86 Installation
Ian3
I downloaded android-x86-9.0-r2.iso from https://www.fosshub.com/Android-x86.html and installed it on my old IBM Thinkpad x40 without error. After rebooting, it said 'Operating System not found'. I tried to boot manually by selecting boot partition with no luck. I also tried to run it without installation but it keeps rebooting. Is it because the hardware is not supported, or I should download from other sources? Thanks.
I couldn't make that Android-x86 distro boot in VirtualBox. I guess it's broken. Of course Android-x86 9.0 is very much a work in progress.
FWIW I believe the proven commercial versions of Android-x86, like Bluestacks, are still using Android 7.0 as their base
I've had The x86-64 version of Lineage (Nougat) running happily on an old Dell laptop. I've not tried a newer version yet though.
If this was a problem with the Android-x86 install than you should at least see it start to load before it fails in some way. If you're seeing an 'Operating system not found' after POST than that indicates either the bootloader is corrupt or there's simply no operating system installed. During the boot up process the BIOS does its Power On Self-Test and then the bootloader attempts to start loading up whatever installed OS is on the drive. At what point are you seeing that message?
Have you checked your ThinkPad's BIOS that it has detected the hard drive and that it's listed in the boot order?
