Apps Androiders ,, i need immediate help please !
Musab
hello all ,, how are you doing ,,
am working o a project using my samsung S2 mobile ,,
am collecting data from it's sensors like accelometer and gyro and make some analysis on it on the labview software ,,
my problem is that i need to send these data to the software using the wifi since my laptop does not have a bluetooth card ,, i know how to make it by bluetooth ,, but using the wifi i could only record the data in a data file using the pcremote advance application ,, but i dont know how to read from the mobile to labview software directly just as bluetooth ... i guess there must be a library for labview to read immediately from wifi !
can anybody help me ,, i have been googling it for a week with no results ..
I have no idea what labview is but if it doesn't support wifi, you're out of luck. However, it should still be possible to write a generic server that listens for incoming data and saves it to a file.
Once you have the file you'd need to import it manually.
