Hi
Im new to this forum, and i have a problem that is. I have some add-ons on my droid box, but none have 3D movies on. can some person know what app that as 3D moveis on. Thank You. Watson
OK I guess your device is unbranded, from your answer. There are no 3d apps as such, on the app store. Your box either supports 3d or it doesn't. If you've tried playing 3D movies and they don't work then I guess it's not supported.
Thanks for the reply. I did have two apps that had 3D movies on it and worked OK. but had a problems with the box. So i flashed the box but cannot rember the two apps. The flash program came from androidplay.com.
