AndroidStudio (AS) fails to find the definition of ScriptC_invert when implementing a Renderscript (in another file invert.rs). It is placed in a directory src/main/rs and this is updated in the gradle (AndroidStudio folder). I am using Android SDK 33 which should still support Renderscripts.
I am sure there are no code-wise issues as I am consistent with several examples online, namely, the invert.rs contains:
// File: invert.rs
#pragma version(1)
#pragma rs java_package_name(com.example.sharp)
and the Java code:
ScriptC_invert invert = new ScriptC_invert(rs);
but I get:
error: cannot find symbol ScriptC_invert invert = new ScriptC_invert(rs);
The build.gradle contains:
renderscriptTargetApi 18
renderscriptSupportModeEnabled true
as well as:
sourceSets {
main {
renderscript {
srcDirs 'src/main/rs'
Anyone managed to get this running on current android/AS versions? Thanks!
// File: invert.rs
#pragma version(1)
and the Java code:
but I get:
as well as:
sourceSets {
main {
renderscript {
