Welcome to Android Forums! Sorry for the slow response.
I've never played Angry Granny, but maybe I can give some help. Go into the settings menu, and then into your applications manager. click on Angry Granny to see the options. I would tap force close and then clear the cache. Try running the app again, and if it still doesn't work, go in and clear the data. Be warned, however, this will erase all progress. If it still doesn't work, the last option I know of is to uninstall and reinstall the app.
I hope this helps! If not, there are two avenues: You can re-submit your question with additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
