Animation Speed (Dev Options)
I don't have a Note 8 but I use Developer options to change the Select USB Configuration settings occasionally. Mostly when I'm at a public computer I haven't used before and just want to charge and not transfer files. Feels safer that way.
Following the advice from an article ( https://phandroid.com/2017/10/11/samsung-galaxy-note-8-first-things/), I opted to increase the speed of the animations through the hidden Developer Options. Has anyone made any other changes through Developer Option and if so, what did you change and why.
Thanks
I change the wifi settings so it is aggressive. At home I have a dual 2.5 and 5.0 speed Wi-Fi. And depending on where you are and if I'm watching a movie it will switch between those 2 and my phone network in order to get the best speed especially when you have your 'network always on' .I also have icon on so I know where I'm touching on the screen
