So i haave just dragged the buttons on the activity_main ....
Java:
this here is mainActivity.java:
package com.example.egids.bethehistory_basketball;
import android.app.Activity;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.widget.TextView;
public class MainActivity extends Activity {
// Used to load the 'native-lib' library on application startup.
static {
System.loadLibrary("native-lib");
[USER=1021285]@override[/USER]
setContentView(R.layout.activity_main);
// Example of a call to a native method
TextView tv = (TextView) findViewById(R.id.activity_main);
tv.setText(stringFromJNI());
* A native method that is implemented by the 'native-lib' native library,
* which is packaged with this application.
public native String stringFromJNI();
This is activity_main
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="[URL]http://schemas.android.com/apk/res/android[/URL]"
xmlns:tools="[URL]http://schemas.android.com/tools[/URL]"
android:id="@+id/activity_main"
android:layout_height="match_parent"
android:paddingBottom="@dimen/activity_vertical_margin"
android:paddingLeft="@dimen/activity_horizontal_margin"
android:paddingRight="@dimen/activity_horizontal_margin"
android:paddingTop="@dimen/activity_vertical_margin"
tools:context="com.example.egids.bethehistory_basketball.MainActivity"
android:background="@android:drawable/alert_dark_frame">
<Button
android:text="Custom teams"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:id="@+id/button"
android:layout_below="@+id/button5"
android:layout_centerHorizontal="true"
android:layout_marginTop="65dp"
android:background="?android:attr/colorBackgroundFloating" />
<Button
android:text="Credits"
android:id="@+id/button3"
android:layout_alignParentBottom="true"
android:layout_alignParentLeft="true"
android:layout_alignParentStart="true"
android:layout_marginLeft="20dp"
android:layout_marginStart="20dp"
android:layout_marginBottom="31dp"
android:backgroundTint="@android:color/white" />
<Button
android:text="Start The Journey"
android:id="@+id/button5"
android:layout_marginTop="30dp"
android:layout_alignParentTop="true"
android:layout_centerHorizontal="true" />
<Button
android:text="Quit"
android:id="@+id/button4"
android:layout_marginTop="48dp"
android:layout_below="@+id/button2"
android:layout_alignRight="@+id/button"
android:layout_alignEnd="@+id/button" />
<Button
android:text="View Rosters"
android:id="@+id/button2"
android:layout_marginTop="78dp"
android:layout_below="@+id/button"
</RelativeLayout>
