Is there an easy way to answer calls? Nothing shows on my screen when it rings. I have to swipe from the top just to get an answer button, then swipe again when the phone screen opens.
Have you tried a factory reset? Unless another app is in the foreground, you should see the dialer call dialog which is the bumping contact photo at the bottom which you slide up to answer or down to reject. There's also a message icon to the left that allows you to reject a call with a text message follow up.
