Nonny Mouse
The main devices on my local network are:
* Computer (192.168.1.68)
* Laptop (192.168.1.66)
* Smartphone (Xperia XZ2 Premium / Android 9) (192.168.1.72)
They connect through:
* Router (192.168.1.254)
Everything can ping the router
The router can ping everything
Everything can have net access through the router
The computer and laptop can ping each other (through the router)
.... but for some reason, the computer and laptop can't ping the phone, and vice versa.
I've been boggling over this and have run out of ideas. Nothing is running a firewall (router, computer, laptop, smartphone). Routing tables on both the computer and laptop are nothing special.
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default dsldevice.lan 0.0.0.0 UG 600 0 0 wlp0s29u
1u8u1
192.168.1.0 0.0.0.0 255.255.255.0 U 600 0 0 wlp0s29u
1u8u1
192.168.124.0 0.0.0.0 255.255.255.0 U 0 0 0 virbr0
default dsldevice.lan 0.0.0.0 UG 600 0 0 wlp3s0
192.168.1.0 0.0.0.0 255.255.255.0 U 600 0 0 wlp3s0
192.168.122.0 0.0.0.0 255.255.255.0 U 0 0 0 virbr0
The smartphone, as mentioned, shows up fine in the router's interface, and it's built-in ping utility can ping it (and vice versa). There's no special routing parameters that can be configured in the router interface, and it looks no different than any other device on my network.
Any ideas as to what I can do to try to "socialize" my smartphone with my other devices?
1u8u1
1u8u1
