N
note4calendar
Guest
I've owned my Note 4 for about a month or so now.
I'm an active calendar user, but recently I stumbled upon this problem where Samsung's own calendar shows a blank page when I try to create a new event the "navigation" from where you can choose whether it is a task or an event, is still visible. If you switch to "Add task" and then back, you can see almost all the fields but you can't even change the times of it. (No, my event isn't 1/1/1970 at 0:00.).
Google Calendar however crashes when trying to create a new event (pressing the red plus button).
