I use both Endomondo Pro and Cardio trainer free.
I have noticed that Endo is a little bit less in the distance stakes, and since getting the OneX Cardio trainer has increased the distance slightly over my old Hero. I actually ran 11 k recorded with it for the Bupa 10K in May, so I am sure it is slightly out.
Does your app have a stride distance, that might be a measurement calculator, as i think it uses that to try and get a bit more accurate. There are also different settings on CT for the GPS accuracy.
Noticed a similar issue with Endomodo, on my first handset, my run/cycle was always circa 6 miles, yet on my replacement, it is over 8.
Does Google Maps, or any other app that uses location, report you being where you're supposed to be?
