Any way to create voice-to-text messages?
droidros
I am terrible at text messaging because autocorrect is always substituting what it thinks I meant instead of what I typed - even if I have typed a perfectly normal common word spelled correctly. My daughter, who has an iPhone, asks me why I don't use voice input instead of typing. Well, because I can't find a way to do it. There's a microphone icon on the keyboard, but when I press that it tells me to hold to record and release to send. Then it creates a voice recording, which is definitely NOT what I want. I've checked all the settings and don't see what I'm doing wrong.
Is there a way with the default message app and Google keyboard or do I need to install something else?
When I'm driving I say "OK Moto Z, send a message to Bill" which opens Google
One way I use is to long hold my Home button (the center Circle key) which brings up Google Assistant. Then I say "send a text." The Google Assistant will ask who to, and away you go. I also have my phone enabled to respond when I say "OK Moto Z." Then I give a command to send a text, which again activates the Google Assistant.
Thank you very much, the long hold on the Home button works as you describe. I didn't know about that trick.
But I have now discovered another problem. "OK Google" or "OK Moto Z" does not work. I have enabled OK Google and Trusted Voice, but nothing happens when I say it, regardless of which screen I'm on. I tried to retrain voice recognition, but after I say OK Google three times, it tells me "Can't use the microphone. Restart your device." Restarting doesn't solve the problem ... even in Safe Mode.
The microphone is obviously working because I can tap the microphone in the Google search bar and input a command.
I'm not sure whether OK Google has ever worked on this phone as I don't use it much. I know it worked on my previous phone, a Samsung.
I don't use the OK Google or the Trusted Voice in the Google app settings. I use the Moto Voice option in the Moto app. I don't believe that both Moto Voice and Google voice work at the same time. It's one or the other. So for me, whether the phone is awake or asleep, it's OK Moto Z to activate any voice search, text message or call.
Okay, that explains it - thanks again. I didn't know about the Moto voice function. I enabled that instead of Google voice and it works.
I guess I need to spend some time learning about this phone. I previously had two Motorola phones prior to my last one, a Samsung S5, so I thought I knew how to use it. Seems I don't!
