I miss that Iphone feature that lets you know you made a good connection and the phone is charging. I have come downstairs a few mornings and found a dead or nearly dead One X because of bad charger connection.
I'm not sure if you can by default, but there are various apps you can use to make the phone perform certain tasks when you plug things in. Plugin Launcher might do it?
The notification light is lit up red when its charging and green when charge is full. thats how you know, plus the battery on the notification bar has a lightning bolt through it while its charging
