666cowboy
Found this while searching Nougat stuff. Most of the rest of tips in the link worked just fine.
Unlock System Tuner UI: This is a clever hidden setting that offers a range of options you can't otherwise get to. You have to first enable the developer settings (as above). Then you swipe down the Quick Settings and press and hold the settings cog at the top next to the battery. After a long press, the System Tuner UI will be unlocked, and a new option will appear in the settings menu.
http://www.pocket-lint.com/news/138...s-get-your-teeth-into-google-s-gooey-goodness
