Anyone have Lala.com running on an Android phone w/Flash?
such as the HTC Hero? I heard Flash is still slow on the Android phones that attempt to run it. I'm just wondering if playing music on Lala runs smoothly, i.e. decent audio quality, little or no skipping.
Thanks.
Hello.
I have tried it. And it doesn't load. It comes up with a message saying you browser has a flash player but appears to be blocking the programe. I can't find anything to change any settings with the flash player either. So for now it looks like flash needs updating more to run lala.
Depending on the amount of signal/wi-fi you have will effect how smooth the video will play. I have played quite a lot of things quite well. Its not brilliant but better than nothing at the moment.
