Anyone using tfs shell launcher?
kurtyyyyyy
Tryimg out this expensive launcher, and i have to say, its SUPER smooth. Really liking it so far. Just wondering if anyone else has tried it and what your thoughts were.
I just started using it this week. Had $25 play store credit from the Nexus 7 purchase so I needed to use some of it.
Really pleased with TSF so far. Definitely takes some learning but that was part of the allure for me. It runs super smooth and hasn't affected battery life at all. If it were a little cheaper I think lots of people would use it.
I installed it yesterday. I have used Apex, Nova, TouchWiz, Go Launcher, & Trebucket. I really like the animations and the super smooth transitions. My only suggestions for the TSF Shell developers is to make ALL the Pullout menu's tabs to be customized/hidden. For example: I don't use the Animations, so I would like to "pull off" the widgets on it, and re-purpose it for more apps, perhaps "System Tools". It's an expensive launcher, and if you got the cash, go for it.
Once. lacked options at the time. Grid layout, gestures, hide dock and status bar etc
It has really been much improved with the last two updates.
Not a battery hog as it was on the initial release. :thumbup:
One problem ive noticed is when hitting home sometimes it says tfs shell is loading, which is a little annoying. But cant believe how smooth it is scrolling.
Definitely my favorite one of all the launchers I have tried. I really like how smooth it is. Looking forward to some future updates.
I keep being tempted by it, but for now, I'll just lurk in this thread and see what you guys say about it ;)
Here's how mine is set up now. I can't really say anything bad about tsf they did a great job.
Im not 100% happy with it. I get tsf shell is loading after browsing or viewing pics in gallery. Wish theyd fix!
Mine used to do that as well-fixed it from two updates back. Try putting a different launcher on/uninstall TFS /then reinstall TFS. Hopefully it corrects it.
